Parting Out Parting out a 95 FJZ80 Green with a Tan Interior
This is a complete running truck. Minor damage to the grill and front bumper. No damage to the frame or core support. I am pulling all the normal things but if you need an interior panel or something out of the ordinary let me know. The frame is in good condition is someone needs it. I am currently out of town but I will be back to get pictures on Thursday. After the item you will see the package size by USPS Flat rate boxes (sm, med or lg). Otherwise the size and weight of the package is provided. Photos are available.
direct email: josephpatrickgray@yahoo.com
Seat belts (all seat belts except for those attached to the seats) LG
Pass flare 26 46 6 3lb
Rear flares 32 14 6 2lbs SOLD
Rear mudfllaps with hardware 22 14 14 2lbs
Console 19 24 10 8lbs
Gauge bezel 25 8 8 1lb
Lower left dash 22 6 6 1lb
Heat/AC controls med
dasd Plastic no switches 18 12 12 1lb
Fuse cover
Steering column clam shell lg
Transfer case console 20 14 8 3lbs
Glovebox 16 14 10 2lbs
Radiator overflow me
Wash fluid 12 12 12 2lbs
Rear DS 42 6 6 21lbs
Front DS 35 6 6 18lbs
Crossmember 35 8 5 16lbs
Rear springs 21 12 12 22lbs
Front springs same
Tie rod 50 4 4 8lbss
Air cleaner 18 18 18 13lbs
Rear wing 46 6 6 5lbs
Antilock controller lg
Antilock brake lines 30 15 6 1lb
Shifter 13 13 13 5lbs
Hood latch and cable meds
Cruise motor med
Rear seat brackets third row 17 6 6 5lbs
Front skid plate 33 12 3 2lbs
Transfer case skid plate 9 12 2 1lb
Master cyl and booster 20 13 13 13lbs
Steering box 19 16 8 40lbs
Engine harness med
Sunroof deflector with
hardware 45 10 4 2lbs
Wiper motor med
Coil and ignitor c
Hood props 20 4 4 1lbs
Engine Computer med
Steering column 22 18 18 28lbs
Fan shroud 31 21 4
Rear window switches med
Battery box with hold downs 18 18 18 3lbs
Doors (pick up only) and door panels
Full set of leather seats (local pickup only)
WHat part of the world are you? I am looking for an engine.
I am looking for a steering wheel if yours is in good shape. I will email you.
I am looking for a rear passenger (drivers side) door lock actuator. I am also looking for the Upper seat back recline button for the drivers seat, preferred in brown. Prices shipped to 84003. Thanks
I need a door lock actuator as we'll for the rear passenger side door and a lx450 hub cover to 98607.
Pm please.
image1.webp Looking for DS power seat buttons for a friend of mine. Will take the assembly if that's what it takes. He's missing the top button.
Looking for rim's center caps. Do you have any? If so, how much? Let me know, thanks.
How much for rear carpet shipped (if it's in good shape) to 60137. I'll also email you.
i need several small parts:
small 4" throttle cable bracket that goes from head to cable
large screw that holds upper part of the interior door handle/arm rest to interoir door panel.
small .5 inch square plugs that are on the "grab handles" in the interior around the head liner, need about 6.
also need a brown interior e brake boot if yours is in really great condition with no holes, tears, rips or thin spots.
OEM Double DIN stereo if you still have it. And the clip that holds the passenger side sun visor in place. Power antenna too. To 81435 zip
