- Location
- United States
2000 Lexus LX470 PARTS:
White exterior with tan leather interior
*******GETTING LOTS OF POSTS >>>> BUT IF ITS NOT ON THE LIST I DONT HAVE IT, ITS SOLD OR WAS DAMAGED ****
***open to reasonable offers on all parts***
items located in winnipeg, manitoba, canada, willing to ship anywhere
Interior / Electronics:
- driver underdash panel
- glovebox
- front ashtray assembly
- middle row map lights / domelight
- rear cargo dome light
- passenger A-pillar trim panel
- passenger B-pillar trim panel
- L + R cargo area upper trim panels (some small cuts, marks)
- right cargo area lower trim panel
- rear OEM cargo mat (1 inch tear around one seat hole, not really noticable)
- rear seatbelts
- ebrake handle
- transfer case shifter-body rubber seal
- 4wd black leather shift knob and leather boot
- fuel door release cable
- driver kickpanel fuse box cover
- L + R door tweeter cover
- various seat mounting bolt cover panels for front and rear seats
- various interior grab handles
- L + R nakamichi front door tweeters
- all 4 nakamichi door speakers in mounting shells (drivers has small crack and one mount hole cracked-still usable)
- nakamichi subwoofer, no box
- nakamichi amplifier
- 1 rear vent motors
- passenger front door power window motor and regulator
- driver rear door interior handle w/ cables and power lock/latch mechanism
- passenger front door interior handle w/ cables and power lock/latch mechanism
- passenger rear door interior handle w/ cables and power lock/latch mechanism
- rear gate power lock assy
- rear gate wiper motor
- rear gate wiring harnesses
- rear gate latch cable (right side)
- ignition switch with immobiliser unit (metal housing broken off coloum)
- theft warning computer - 89730-60010
- antenna relay control unit - 85914-60070
- receiver, door control 89741-60061
- controller and junction computer (center of dash) 82791-60031
- running light relay box
- passenger kickpanel junction box
- dash dimmer switch and trim panel
- glovebox light switch
- memory seat switch
- ahc computer 89290-60021
- tilt + telescopic computer 89227-60021
- abs + trc+ vsc computer 89540-60160
- cable reel and telescopic switch (airbags deployed)
- L + R rear window switches (no ashtrays)
- L + R rear vent window switches
- windshield wiper switch (from coloum)
- power mirror switch
- auto light sensor (from dash)
- rearview mirror - autodimming (wires torn off)
- all wiring harnesses in various condition from whole vehicle including doors
- front heater core and servos (case damaged)
- front blower motor with control unit
- rear heater core with blower motor and resistors (case damaged)
- rear a/c unit complete
- rear heat / a/c controls
Exterior:
- passenger front fender
- passenger front fender liner
- passenger front door complete (will seperate all parts)
- passenger rear door complete - no glass (will separate all parts)
- passenger exterior rocker body moulding
- passenger front fender body moulding
- passenger rear quater panel body moulding
- rear tailgate body moulding
- driver rear door body moulding
- driver rear door exterior window drip edge moulding
- driver rear section of runningboard plastic cover
- driver running board tread plate (end screw holes cracked)
- passenger rear mud flap
- hood mount washer jets with hose
- hood gas supports
- front grill (no emblem)
- driver rear door exterior handle
- hatch gas support (1 only)
- front skid plate
Drivetrain + Suspension:
- oil pan
- 8 ignition coils
- heads (not yet removed to check for any damage on the blown cylinder
- starter with wire harness
- power steering pump and tank
- a/c compressor
- engine mounts (driver side shield bent, still sits straight)
- alternator
- cats and 02 sensors
- Evap tank complete
- high side a/c line
- front driveshaft
- ebrake cable
- passenger tierod end
- rear springs
- torsion bars
- L + R front brake calipers
thanx, jay
- glovebox
- rear seatbelts
- ebrake handle
Exterior:
- hood gas supports
- front skid plate
- oil pan
- 8 ignition coils
- a/c compressor
- alternator
- front driveshaft
- ebrake cable
- rear springs
- torsion bars
thanx, jay
