parting out a 2000 lexus lx470 (landcruiser)
2000 Lexus LX470 PARTS:
White exterior with tan leather interior
*******GETTING LOTS OF POSTS >>>> BUT IF ITS NOT ON THE LIST I DONT HAVE IT, ITS SOLD OR WAS DAMAGED ****
***open to reasonable offers on all parts***
items located in winnipeg, manitoba, canada, willing to ship anywhere
Interior / Electronics:
- driver underdash panel
- glovebox
- front ashtray assembly
- middle row map lights / domelight
- rear cargo dome light
- passenger A-pillar trim panel
- passenger B-pillar trim panel
- L + R cargo area upper trim panels (some small cuts, marks)
- right cargo area lower trim panel
- rear OEM cargo mat (1 inch tear around one seat hole, not really noticable)
- rear seatbelts
- ebrake handle
- transfer case shifter-body rubber seal
- 4wd black leather shift knob and leather boot
- fuel door release cable
- driver kickpanel fuse box cover
- L + R door tweeter cover
- various seat mounting bolt cover panels for front and rear seats
- various interior grab handles
- L + R nakamichi front door tweeters
- all 4 nakamichi door speakers in mounting shells (drivers has small crack and one mount hole cracked-still usable)
- nakamichi subwoofer, no box
- nakamichi amplifier
- 1 rear vent motors
- passenger front door power window motor and regulator
- driver rear door interior handle w/ cables and power lock/latch mechanism
- passenger front door interior handle w/ cables and power lock/latch mechanism
- passenger rear door interior handle w/ cables and power lock/latch mechanism
- rear gate power lock assy
- rear gate wiper motor
- rear gate wiring harnesses
- rear gate latch cable (right side)
- ignition switch with immobiliser unit (metal housing broken off coloum)
- theft warning computer - 89730-60010
- antenna relay control unit - 85914-60070
- receiver, door control 89741-60061
- controller and junction computer (center of dash) 82791-60031
- running light relay box
- passenger kickpanel junction box
- dash dimmer switch and trim panel
- glovebox light switch
- memory seat switch
- ahc computer 89290-60021
- tilt + telescopic computer 89227-60021
- abs + trc+ vsc computer 89540-60160
- cable reel and telescopic switch (airbags deployed)
- L + R rear window switches (no ashtrays)
- L + R rear vent window switches
- windshield wiper switch (from coloum)
- power mirror switch
- auto light sensor (from dash)
- rearview mirror - autodimming (wires torn off)
- all wiring harnesses in various condition from whole vehicle including doors
- front heater core and servos (case damaged)
- front blower motor with control unit
- rear heater core with blower motor and resistors (case damaged)
- rear a/c unit complete
- rear heat / a/c controls
Exterior:
- passenger front fender
- passenger front fender liner
- passenger front door complete (will seperate all parts)
- passenger rear door complete - no glass (will separate all parts)
- passenger exterior rocker body moulding
- passenger front fender body moulding
- passenger rear quater panel body moulding
- rear tailgate body moulding
- driver rear door body moulding
- driver rear door exterior window drip edge moulding
- driver rear section of runningboard plastic cover
- driver running board tread plate (end screw holes cracked)
- passenger rear mud flap
- hood mount washer jets with hose
- hood gas supports
- front grill (no emblem)
- driver rear door exterior handle
- hatch gas support (1 only)
- front skid plate
Drivetrain + Suspension:
- oil pan
- 8 ignition coils
- heads (not yet removed to check for any damage on the blown cylinder
- starter with wire harness
- power steering pump and tank
- a/c compressor
- engine mounts (driver side shield bent, still sits straight)
- alternator
- cats and 02 sensors
- Evap tank complete
- high side a/c line
- front driveshaft
- ebrake cable
- passenger tierod end
- rear springs
- torsion bars
- L + R front brake calipers
thanx, jay
- front map lights console / sunroof controls / homelink buttons
- rear ashtray
- cluster (in KPH, 100,000k) top right corner of lens cracked
Exterior:
- hood gas supports
- transmission + transfer case
- front differential assy (front mount cracked)
- rear differential complete assy w/ brakes and all mounting arms
thanx, jay
Jay:
How much for these items above? I'm in Edmonton and need them for a 1998 Land Cruiser.
Greg
greg@pretzlaff.com
Carpet?
greg i'd say maybe around $1500 for all that which i'm sure is a steal but i just want it gone asap cause i'm moving in 2 months and it would be a lot less to have to move : ) plus the shipping price of course.....
let me know if you're still interested and we'll work it all out.
and i sold the carpet on ebay last year, sorry. i think my list up top is fairly accurate to what i have left, and i don't have anything forsure that isn't on there.....
I need a tan cover for the top shoulder point of the seatbelt, basically where the seatbelt attaches to the sidewall of the car.
sorry i have no idea, i'm moving all that stuff sooner than later so i could get a rough weight on it. if i had to guess, the rear axle would be 250-300lbs, the tranny probably 150 lbs, and about 70 for the front diff .... all just guesses
jay
Do you have the air filter housing? If so how much? Thanks.
Scott
How much for the front driver's side lock actuator assembly?
Thanks!
Do you still have the power seat switches? If so I want them. Thanks!
Hi modsquad, I still need a tan cover for the top shoulder point of the seatbelt, basically where the seatbelt attaches to the sidewall of the car. I see in the list that you have the seatbelts, so I am presuming you have the little tan vinyl (or rubber) covers.
I only need 1, shipped to 33073.
Thanks.
Do you have the climate control unit from the dash? I didn't see it on your list, maybe you've sold it. If not, and you have pictures, I'll PM you my email address.
Thanks.
Do you have tailgate cables for sale?
I'm looking for tailgate cables. Shipping would be to Hawaii.
hey Jay,
I'm in Texas and completely willing to pay the shipping. Anyways I'm interested in the following:
passenger side upper and lower control arms
- passenger side spindle complete with hub, half axle shaft, brake disc
and oil pan
I have a 95 fjz 80 as well and would like to know if any of these parts would work on it as well.
Thanks
Victor
