Parting 1996 FZJ80 with factory lockers
Moscow, Idaho
dtownsend at mos*** dot com
(see town name above and fill in the blanks) or PM me
-------------MAKE OFFERS----
I am really only keeping the interior, frame, body,steering column, and brake booster +brake lines, and possibly the stock radiator and fuel tank.
Land Cruiser with 211k California freeway miles is being converted to Cummins 6bt with 1 ton running gear and the following items are surplus from the project;
Running but in need of rebuild 1FZE 4.5L I6 motor+ ECU (Has a bad rod knock, was run low on oil; operator failed to heed warning light on dash) Has genuine Toyota rebuilt starter and Alternator on it.
Still attached to the engine is a good A343F automatic, and h2fa transfer case.
Front and rear drive lines, front and rear axles-- 4.11 electric locking differentials, locker control units, transmission controller, Front and rear bumpers, exhaust (complete with newer O2 sensors), mud flaps,oil cooler, complete A/C system (except evaporator), Air bag system, sway bars, Evap canister, Factory jack and tool kit in bag, spare tire holder, intake system, ABS system,factory stereo( front and rear amps, speakers), 5 16" aluminum wheels with less than 3500 miles on 4 Yokohama Geolandar AT tires.....
All other electronic/mechanical systems that are not needed to operate the essential systems (lights,heat and windows) are also up for grabs.
Send email with phone # and I will call you back, I will take pictures of the tires/wheels and the motor/transmission/transfer case and post soon.
Would consider trades (+/-) for;
RH FZJ 80 Headlight
-Land Cruiser front seats (tan preferable but not necessary)
-Heavy duty transmissions ( Fs-5206a, Fs-5406a, Fs-4205a)
-Cummins SAE 2 Adapter plate/bell housing for above transmissions
-Divorced transfer cases or adapters to marry above mentioned transmissions
Ford super duty drive train/supension components
Bumper sold
Front bumper has been sold
All suspension linkages, panhard, tie-rod, drag-link ( aka relay rod), and on axle brake components have been sold.
Thanks
Front and Rear brake calipers available?
I may, but I have someone that has expressed interest in the complete exhaust. If that does not go through I will PM you.
left rear tail light stlll available?drivers side
Keeping the lights
I am keeping the tail and headlights
"All other electronic/mechanical systems that are not needed to operate the essential systems (lights,heat and windows) are also up for grabs".
The listing could have been clearer (as my wife pointed out).
Sorry for the confusion.
Dana
I purchased the transfer case and everything was as advertised. No nasty surprises and Idahorover worked with me on delivery. Very happy.
Everyone always seems to post when they are unhappy, figured I would try something new. :)
