Hi everyone,
So I just finished putting my rear axle back together. Drums where taken apart so that I could replace bellhouse boot on both drums. The drum shoes and actual drum are the same ones as they where inspect and didn't need replacing. Also, rear axle got new seals and new bearings.
So first issue is my parking brake doesn't work anymore. The light is on and when I engage it on a incline it just rolls. It seems to easy to pull the parking brake lever out compared to how it used to be. I had a very competent board member check to make sure I put the drums back together correctly because it was my first time doing so and he said they are perfect. I have bled all the brakes and the lspv and braking is not an issue.
Secondly, from the right rear wheel well and drivers rear wheel well there is kind of a hot smell coming from those areas. Could be paranoia but I don't want to burn my brakes up. It could be the brake cleaner burning off not sure.
I adjusted the rear brakes my pulling on the parking lever a couple of times. Not sure if that is the right way to adjust the rear drums or not?
