For Sale PA tailgate dash switches both wiring styles
NE PA coal region
Have two nice dash mount switches for the tailgate windows on a 55. Both work as they should electrically and are in good shape. Both have the threaded retaining chrome nut and lock nut. Specify which switch you need- with the plastic 3 wire connector or the one with the individual bullet ends. Price $40 either one plus postage. Best to email me shmukter@pa.metrocast.net
I would like one but not sure which one. Here are the applicable years. I need the earlier one which I assume is the one with the three push pin connectors?
84860SWITCH ASSY, TAIL GATE REMOTE CONTROL
84860-60010(03/1969 - 08/1977)
84860-60011(09/1977 - 06/1980)
- The White 6.3mm / 250 Series Nylon 3pin Locking YAZAKI Connector Housing's is the Later one Mr. Eagle , 9/77-6/80
- 3 Single JUMBO 6mm Male Bullets connectors is the Early one 1968-8/77
- the 60011 by OEM TOYOTA Parts Maker TOKAIRIKA Co. Japan updated the Wires or Leeds connections by incorporating a combination Crimp Terminal and Solder Joint Together all in one location ....
- it appears from the photos above the wire gauge was also bumped up 1 gauge size-spec too ? but i don't know if that's a reliable fact or not ? 🤔
- i have NEVER seen these early Larger 6mm YAZAKI Bullet connectors offered anywhere ?
- so you would need a harness side pigtail with the 6mm Females / and the Sheaths too
- Mr. Shumaker , nicely includes the later 60011 Harness Side Connection here above , w/ his switch offering .... :)
