Owners of 275/70/18 BFG AT/KO's what tire pressure for even wear?
I've run them from 35-50psi. Oddly, I can't feel a difference. And, didn't see any MPG variance either. So, it's all about the wear. 40psi is a good place to start. I say "start" because (and probably why you see the numbers all over the place in your research) it depends on the weight of the truck. Full tank, third row, 'fridge, bumpers, racks...
Do the chalk test. Just put a big old fat line across the tread, drive 1/4 mile in a straight line, inspect your chalk line. Others may weigh (pun intended) on this test - it's been a while since I did it (and research the proper way to do it).
Got my tires on Saturday. I asked the installer and he said 50! So Im running them that way for now. I can feel every bump and crack tho. No more plush ride compared to my 295/75/16. Then again I like the zero roll or plowing feeling at freeway speeds a mid-corner. Only issue I have is a slight vibration at 35-40mph. I have experienced this on heavy bikes (BMW GS Adventure KTM 1190 etc) with knobbies. Its all about finding the correct pressure for the suspension. So im not worried, she feels smooth otherwise. I wonder of I should run different pressures upfront (heavier) than the rear? Most of my cars (sport) recommend that setup/
@Manhattan I like the idea of the chalk.....gotta give it a try.
I run 35-40 on mine.
It's not so much the tire, but what the vehicle requires, all other things equal. Your truck's suspension has been modified and the tire is bigger than OEM. I would adjust it to where you like it to ride, 10psi difference in a good range won't cause any material difference in wear. On the other end of the spectrum, cold 50psi or 25psi may affect long term wear.
My personal preference for truck tires, on road, is cold 35-40 PSI. I don't see any gain going above 40psi. In summer, daytime temps shoot up 30 degrees, plus the heating of the tire on road. In winter, hopefully my tires won't go below 35 PSI.
This thread reminded me of this one - 100 Series Correct Tire Pressure - very confused.
NMuzj100 gave some great advice:
A real professional would get the tire load table grab the vehicle specific axle weights from a reference source and do a calculation. That's what the Bridgestone "Tire Doctor" did for me and produced the perfect pressure of 38 PSI for LT285/75R16 on the 100.
The Michelin guys pressure/heat/pressure/add is a common technique.
The OPs tire is a standard passenger tire and should use the door jamb guides. Then run the chalk, shoeshine, business card and puddle tests to fine tune.
