Hello to all you cruiser heads. Here is my problem. 1977 2F motor rebuilt just installed with a NV4500. I have an electric fan between the radiator and the motor. Running around town I can run with the fan off as long as the lights are not to long then when it starts to heat up I flip on the fan an the motor runs at temp. Today I took it for a shake-down run on a slightly rough road with a good incline not to steep for 4x4 drive. 2nd gear in 2x4 at about 1500rpms with the fan on an it over heats. But only while going up hill it runs cool down hill. I went up the hill once more just to see if it would overheat again which it did. The road is about half mile long with a good incline. I am running the red anti-freeze in the motor not sure if the 2F likes the red or should I go back to the green stuff. Thermostat seems to work just fine an the rad cap is good. I did open up the heater valve
(finally) to get all the air out of the system before heading back down hill. It ran cool even after I turned the fan off when I hit the pavement. I did have to put about a quart of H2O back in the motor once I got it to cool down at the top of the hill.
