I'll be getting the 3FE back from the machine shop later this month, and I have the new H55f sitting in the garage. It's being kept company by the H42/split case from my '86 FJ60 (future recipient of the 3FE/H55f) and the A440F/split case from my '89 FJ62 (the donor). So it's time to start getting the rest of the drivetrain ready. Because the complete FJ62 wiring harness and dashboard will be going over to the FJ60, I have the option to retain the FJ62 split case with vacuum transfer or use the split case from the FJ60. They both have the 38mm idler shaft, and as far as i've been able to research, there's not much difference between the two split cases other than vacuum vs. manual 4WD engagement.
The FJ60 split case has a little over 120,000 miles on it, but the vehicle hasn't been running for about 20 years. The transmission/split case has been stored sealed up and protected from the elements inside the garage for a majority of that time. The FJ62 split case has about 165,000 miles on it and it came out of the running vehicle about a month ago - no known issues with the split case.
As far as vacuum vs. manual 4WD engagement I really don't have any preferences - I've driven my various Land Cruisers with both set-ups. Are there any real advantages/disadvantages between the two split cases I may not be aware aware of? Or should I go with the split case that's in the best mechanical condition? I'll be able to tell that once I separate both from their transmissions.
Any input is welcome.
