- Thread starter
- #141
Your bumper is different than the style I mounted mine too in this thread. I'm not positive, but I believe you have a different like subframe / way of mounting your winch.I'm going to be doing this soon, ARB 3413190 (03-07) is shipped and I snagged the Badlands Apex 12k synthetic on Black Friday for $485.
Since I have an LX, I'm assuming I'll need to relocate the control box somewhere under the hood, since the grille opens with the hood and I will already need to cut the antenna mounts off the ARB just to get the hood to open. Any suggestions on something to use as a smaller control box?
Will likely be heading over to a friend's place to do the entire winch + bumper install in a day so I'd like to prep what I can beforehand. Seems like I still need the following items:
- Longer bolts to mount the fairlead through the hole to the winch
- Smaller housing for the control box
- Cutoff switch and battery terminals
It's been a while since I've though about this but if I'm not mistaken yours mounts feet forward so everything in this thread won't apply since mine was mounted feet down on the subframe platform
- Not sure about longer bolts
- Shouldn't need a smaller control box, I believe you could mount it on top of the bumper like I have done, but then again I don't know if the newer style has different dimensions as well
- Cut off switch comes with the 12K Badlands switch
- I went with the Slee battery terminals. Expensive but great for future expansion of more power and a nice clean look . It required some crimping of wires
