mobi-arc said:I've had those cables corrode and snap.
There is not a spot of rust anywhere on my 470... except the tailgate cable, be warned, even in the non-rust belt, it could be a concern.SINCITY100 said:Well..at least thats ONE thing I dont have to worry about out here in the desert![]()
I like CDans idea...I never really thought much about the carpet/board insert, but it would be nice to fire up a stove on the "gate" without worries of a torched trim panel![]()
Yet ANOTHER mod to do...sometime...![]()
bingo!! It is the cables that you have to worry about. I changed mine out for this very reason...mobi-arc said:I've had those cables corrode and snap.
firetruck41 said:There is not a spot of rust anywhere on my 470... except the tailgate cable, be warned, even in the non-rust belt, it could be a concern.
Yeap, check 'em. I replaced a snapped one too.Noah said:bingo!! It is the cables that you have to worry about. I changed mine out for this very reason...
now i can jump on it all day long...![]()
whats up bro I need to replace both of mine cause they snapped when my 77lb pit bull jumped on it. where did you get the replacments cable besides the dealer?????98LXand99LC said:Yeap, check 'em. I replaced a snapped one too.
98cruiser said:whats up bro I need to replace both of mine cause they snapped when my 77lb pit bull jumped on it. where did you get the replacments cable besides the dealer?????
Morty said:Broke both of mine when they were about 5 years old and dented the tailgate when it hit the keys, which were sitting on top of the bumper. From what I could tell, the water gets down inside the plastic covers that surround the cables and sits down in there. On my new cables, I cut the plastic in the middle so it would drain. No problems so far.
ELLTEE said:The passenger side cable broke on my '99 two years ago. The cable had corroded and just my weight (155 lbs) on the gate did the foul deed. The driver side cable was clean and bright, so I just replaced the pass side and was good to go.
LT
Dandon said:I think I'll also make a small cut it the middle of each sleeve to prevent water from gathering there.
