•• Werewolftech "Bolt On" Portal axles and tire inflation kit for GX 460
PNW
Website
lexusgxor.com
  • Like
Reactions: r2m
On GXOR vendor states:
"The project was built a few years ago. Using in rough off-road conditions. Mileage should be verified with the owner. There have been no problems. No problems detected at 170 km/h."
"With our gantries, you can fit 38" + tyres without damaging the vehicle. +You'll be able to install CTIS."
"The gantry axles alone (not including the wheels) will add 130mm to ground clearance."
"No problems with speed. About 500 miles at an average speed of 165-170km/h without stopping has not resulted in heating or any other problems."
"We recommend retrofitting WEREWOLF steering dampeners. +500$. No further installation is required."
"The kit comes with all the necessary bolt-on parts."
"In everyday use, there is virtually no noise at medium speeds. At higher speeds, no noise can be heard due to the large wheels and engine working."
"You don't have to worry about safety. In over 6 years we have not had a single negative comment, breakdown, repair or return."
"When using 38-39" wheels, the rpm will be the same as on standard wheels without gantry axles."
  • Like
Reactions: r2m
For those that don't know... same basic setup as an AMG G63 4x4 squared.. just an example beyond other obscure rigs many might not be aware of
  • Like
Reactions: r2m
I think I posted something, albeit, not as thorough as your post, on these guys in my build thread.
For me, that would be the ultimate mod.
