One 60 with bent axle
no that picture is just an example of the use of a puller on a tie rod end.
If you open the hood, stand facing the motor, look down and to the right your steering box is sitting on the frame, now get on the ground and look up from the drivers side front tire you will see an arm coming off that steering box. that is your pitman arm, at the end is the tie rod end you need to remove. ill take a picture of mine tonight if someone else hasnt posted one yet.
Yup, I know what you are talking about... class is in session here.:)
So, for those who have replaced or switched axle housings with all the inners in place...how long did this procedure take.
Pinion angle on the 62 housing is different than on the 60 housing. Might not be a big deal but could cause vibrations when driving with the front hubs locked in.
Never notice that .. ( good advice ) diferent 3rd members thought.
Are more upward ?
