I'm resurrecting a previously discussed topic regarding the stock rubber isolator pads that mount above and below the rear leaf springs (see threads below for pictures).
https://forum.ih8mud.com/showthread.php?p=778797
https://forum.ih8mud.com/showthread.php?t=95924
This weekend I was installing a 2.5" OME suspension kit on my 1987 FJ60 and decided to reinstall the rubber isolators to take advantage of the spring-centering features built into the isolators. However, I was only able to torque down my u-bolts to about 70 ft-lbs before the spring seats actually began to bend. I am almost certain that the spring centering features both above and below the spring pack were properly aligned. However, the lower rubber isolator is much thicker and stiffer around the spring centering hole and I believe this resulted in uneven load distribution between the spring seat and the spring pack and eventually resulted in a bent spring seat when enough torque was applied to the u-bolts. So I managed to bend everything back into shape (with a little help from the torch) but I need some advice on proper install. Has anyone used the OME spacers that provide spring centering w/o the rubber isolators (MAF part # OME-CBS01). Are these just cylindrical spacers that press fit into the spring seat, or do they have some sort of flange? Anyone experience this situation where you were actually bending your spring seat? Thanks for any advice on this, I'd especially like to hear from Kurt or Steve0 or anyone else well-versed in OME install.
CC
CC
