All -
In the process of installing my rear BP-51s. Front was easy and took a few hrs, mostly due to bracket fiddling and such.
On the rear the instructions have you install a weird order of washers on the lower shock post.
There are three washer sizes they send you:
-small, x3 per shock
-medium, thicker than others, x1 per shock
-large fender washers, very thin.
Per the instructions they go in this order, on the post:
This seems weird to me. Is it for clearance? This makes part of the shock body sit off the post and the three small washers go IN the bushing, to almost create a post extension/spacer.
This also seems to make the OEM bolt, as called out, seem too short to effectively have bite.
Photo of stack up:
Looking into bushing w/o small washers:
With 3x small washers inserted (bolt can't even grab threads). Going to grab a tap and new bolts and try again:
I contacted ARB who's response was "i'm not sure, call cruiser outfitters." Called Cruiser Outfitters (felt guilty even asking since i ordered through ARB direct), they weren't sure either since their installer was out. Still they were more helpful than ARB and nice as hell even when I told them right off the bat I didn't purchase from them (sorry/thanks @cruiseroutfit )
Just wanted to see if anyone had installed rears themselves, or can look at theirs to see if this is how it is installed.
Photo of stack up:
