I recently installed the below OME lift on my 2013 TLC200:
OME2723 Rear Coil Springs
61029 Rear Shocks
91005 Front Struts
OME2703 Front Springs
Dobinsons UCA's
Then I had the truck aligned. It drives straight down the road and corners just fine. The issue I'm having is every time I hit a dip in the road, go over a railroad crossing or basically compress the suspension, the rear end feels like it's swaying or pulling side to side. I've noticed the rear axle is pulled about 1/2" to the driver (left) side and sticks out a little further. Is this pretty common on a lifted 200? Will a rear adjustable panhard rod / track bar fix the rear end sway? Or will it just help center the axle again? It seems like most people with a similar lift don't have to do anything other than install the new springs and struts & shocks. For the heck of it, I had another shop do an alignment today and they suggested the adjustable panhard rod too.
My 200 currently has front bull bar & winch, rear drawers and a full 33" spare under the truck. I even added a couple hundred pounds to the rear per ARB's recommendation & given OME2723's constant load of 250-440#'s. The extra weight actually made the side to side jog more pronounced. I'm running out of ideas and I'm pretty sure I've reached the end of Mud searching for answers. Let me know if anyone has some input.
61029 Rear Shocks
91005 Front Struts
Dobinsons UCA's
