Old F engine valve adjustment (1 Viewer)
dmaddox
Long Island, NY
In reading the old F engine repair manual. Here is what it says:
1. engine to 170-185F
2. Check headbolts, rocker shaft bolts torque.
3. Set engine to 500 rpm.
4. Intake to .25mm
5. Exhaust to .35mm
It has been awhile since I have done this (on my 2F) and if i remember correctly, I set #1 to TDC compression stroke and then set the valve clearance of some valves, then 180 degrees on the motor and set the rest.
Is this implying I do this while the F engine is running? Time to invite a friend over? Tips? Tricks?
Thanks guys,
Dallas
FYI - I have also posted this in the FJ45 section.
Isn't this mentioned once or twice in the FAQs? or the tech links?
( I do mine with the engine hot, but off. Find #1 TDC, adjust valves 1,2,3,5,7,9.
Turn crankshaft 360 (dizzy rotor tuns 180) and do the rest.)
