Good point about the roofI had to ask because I could not get my 130lb 37" Swamper on the carrier of my old 80 alone. looks like it will work well for you.
Mine is 100 lbs rim and tire - not light, but doable. 130 I'd need help for sure
Dont get a lot of photo radar tickets with that bumper eh?![]()
Lookin good man.
For my license plate light I just plugged into the trailer harness, works good and its simple.
D
I can lift the tire up onto the mount - it's not much fun, but sure beats putting it up on the roof.
Now if the tire bracket was on the other side, you could tilt the whole assembly down and just plop the tire on, then swing it back up.
That design would most likely decrease departure angle clearance. One would have to model it to really see I guess.
Yeah, I wasnt too worried about departure angle since it isnt my primary wheeler. I also wanted to keep the tire down low to maximize rear visibility. It would be pretty simple to design one with the tire raised resulting in more clearance.
Im thinking of something along these lines for my 60. The 1/4 protection would be part of the bumper though and the carrier would attach like the one that poison spider sells for heaps. It wouldnt attach to the body like theirs does cause thats just silly.
Kinda like this
Combined with this
With 1/4 protection like this
I have it all sketched out and am just waiting for winter to go away.
D
I was thinking that a early tacoma style spare winch that uses a cable instead of chain would work. Weld the stock spare tire tool to the winch and turn it into a cool handle that youd rotate to release the tire.... Seems like it could be an alternative to going the ratchet strap route which is a little obvious to potential tire thieves.
You mentioning adjustment made me start thinking about building it into my proposed design. Looking at the 80 carrier in the pic above, it looks like it would be possible to make the whole basket adjustable. You could make it slide up and down on the main tubes and have a couple different holes for pins. A set screw knob to get rid of play in the sleeved tubes, maybe some grease fittings. Drop it for driving around town visibility and lift when wheeling...
I love tossing ideas around like this.
D
This was from post #2. I don't know where he got this, but it ain't true with my Kaymar. The only mods I've made was to remove the original Kaymar provided aux lights and install some additional backup lights in their housings. Also the keeper that holds the swingout open wore out, but a replacement was easily fabbed from a bolt. Here's some pics from Oct. 2010. You can see the keeper in the pics. It's the bent bolt near the spare spindle.........I like the Kaymar and it will fit with the aux tank, but the bushings in the swing away carrier wear out too quick and the tire shakes too much for my liking............
I wanted to fit an aux thank, and with that came the necessity of a rear tire holder, and then a rear bumper. I planned to go for the Iron Pig bumper, but the weight frightened me. To expedition equip a vehicle means adding a lot of weight. So I got this idea of instead of adding a new bumper outside the existing, I would instead change the plastic corners with steel. The added weight with this design is 20 kg, instead of 70. And of course many bucks less..
As I have no tools for bending thick steel I had to find standard parts that only needed grinding and welding. The rear member is a 6 mm U-profile that perfectly fits outside the standard bumper. The side wings are made of two 5 x100 mm flat irons welded together, with a 25 mm square tube on top. There is also a rod from the wing to the U-profile to stiffen this sideways. (Not shown in photo). I did not use the frame to stiffen the side-wings as I have seen on other designs, as I am afraid a sideways hit could bend the frame.
So far only left side is finished, the right side is for the upcoming winter.
The 30mm pipe underneath is an idea stolen from Land Rover. It fits their Hi-Lift adapter.
The swingout and wheel carrier is from 4x4 labs.
Erwin, is your tire carrier the 4x4labs version?
Yes it is. Here is a writeup: Inditravel.orgErwin, is your tire carrier the 4x4labs version?
