When tooling around town ive noticed that the oil pressure gauge takes forever to build up. How long should it take? What am I looking for/at to rectify this?
Thx
Thx
Good. One down, one to go.This reply is late for sure, but it did get done---Tested the gauge as per your and FSM instructions---gauge and light responded as good.
If you used the right wattage bulb the light should be dim (but not very dim) and the frequency of the flashing should vary with the rpm's.When testing the sender- the bulb initially was bright, then immediately went out, then VERY dim and fluctuating(engine RPM was ~ 750)
I don't know the "cold" resistance but I can check tomorrow at daylight. I've never checked it but looking at the FSM it shows that at no pressure (engine off) the circuit is open, which means no resistance at all and that is also what the FSM says. "the bulb should not light when the engine is stopped"I checked the resistance on the old sender(the one I thought failed) and it read 50.6 Ohms. Checked the new sender and the resistance was infinity(engine off). Sounds like you have it pegged--the new sender has too much resistance---
How about buy an OEM one or an aftermarket from a reliable vendor?So how do I get a sender with the correct resistance? Do you, or anyone else, know what the correct sender resistance should be?
Yes--did the same test--it started at ~58 Ohms and stayed there up to the 100 psi I tested at.- since it seems to be working now--maybe I blew out some gunk??
Come to think of it, this might even be a novel way to troubleshoot a non-responding oil pressure gauge---Do the 3.4 bulb check, and if that doesn't work, pop the sender with 125 psi air a couple of times to see if the sender is just gummed up.
