Oil pressure sending unit
izzyandsue
Izzy
Charlotte, NC
Website
www.tactegra.com
Can anyone tell me where it is? Looked through the FSM and can’t find a diagram for location. Last weekend I replaced all coolant hoses and clamps with Toyota, so probably knocked something off? The needle is dead in the dashboard, otherwise all seems fine. Thanks!
oilpressure-jpg.1058053
Thanks Al, and thank you Vee-man for jumping in with prospect replacement. So.... found the issue, There is supposed to be a wire on this black connector. Found the wire on the loom, too short.
1932691
So need to elongate wire and reconnect. Disconnecting the ground wasnt fun, and it is corroded as hell.
1932695
Anyway, removed the harness and did some bench soldering, remembering to insert the shrink tube BEFORE soldering. Then some emery paper to clean all the ground corrosion, reconnect everything and we are back in business, oil pressure is present and accounted for.
1932696
