Oil Pan Part Number? (1 Viewer)
Boulder, CO
I’m about to order a 12101-61013 but looks like it’s for a FJ40. Will it fit a FJ60? I assume all 2F pans are the same but I’d rather not ship it back. Thanks in advance!
Also, bonus points if you have the oil pan bolt torque spec.
Yes.
Make sure to also get:
12151-61011
90341-12012
90430-12031
I will have to check in the morning but I believe that’s the pan I ordered for my 60 Series 2F. Be aware that there used to be part numbers for the 40 Series 2F, 60 2F, and 62 3F/E, and they have now been consolidated into one part number - @OGBeno can probably confirm or deny that. In any case, one of the baffles in the pan was about 1cm different compared to the pan I took off (assuming original) and it caused interference with my oil pump pickup and dipstick. There’s a notch in said baffle that need to be clearanced and the small bend on top of the baffle had to be relaxed for the dipstick.
I documented this in my build thread here. Info on the bend for the dipstick tube is on the subsequent page.
