First time posting on MUD. Have read a ton, and have gained a ton of insight. What a great site for an FJ owner. I have been working on some oil leaks on a 77 FJ40 that I recently purchased. Thanks to MUD, I pulled the tranny/transfer case, clutch, flywheel, replaced the rear main seal, removed the oil pan (stuck on there major), and the old oil pan gasket. Now I am beginning the re assembly process and have all the parts, so I think. I bought an engine gasket set off of cruiser corps, and I cannot seem to get the oil pan gasket to fit the oil pan properly? I haven't done a ton of oil pan gaskets in my life (actually zero), but this thing does not seem to match up to the oil pan without me altering it to some degree. I have tried to lengthen the corner holes to make the ends of the pan match the gasket better. After some head scratching, this just doesn't seem like a good idea. I may have been burned by the non-oem part problem. Does anyone have any experience with these gaskets? I suppose I should just order an OEM gasket, and go from there. I just don't want to get that one and it does the same thing? I appreciate your time and patience with me in this matter.
