Here's another thought.
Fix all your vacuum leaks.
Why?
Because the PCV valve is designed to keep a NEGATIVE pressure (vacuum) on the crankcase.
If there are too many vacuum leaks (valve cover gasket, spark plug tube seals, vacuum hoses) then the PCV cannot do its job and the crankcase will go to a pressurized condition or at least a neutral pressure condition.
If under pressure, then there is "air" that will be pushing oil OUT at every seal, orifice, hose, and possible leak area.
If you are under a vacuum, then all these areas will suck in air or at the very least keep the oil from seeping. The most important area I see this on is the distributor INTERNAL seal. The distributor cap has a hole in it that allows air to equalize and oil to drip out from inside the cap, yet it has a seal at the base to keep out water from above.
Fix your vacuum leaks and this just may go away.
