It is likely crank seal was replaced before! Possible leaking before, and not cleaned as you suggested. AS is a lot of gunk. But also consider it's may have just leaked since last T-belt service. Which is 90K miles 7 years. But wherever leak(s) is/are from, it is active now. So bad, oil drip/spot on my shop floor in only a day in.
I took this picture 15K miles 1 yr ago.
Today. Clearly a lot more gunk, just 15K & 1 yr later
It's also, now that I think about. Possibly in part due to excessive crank case pressure!
This has been a difficult T-belt jobs. Alternator 12mm nut stuck on stud, requiring alternator be removed (second in as many weeks). Very common RH T-belt cover crown nut stuck on stud (happens every time over torqued). Fan bracket top side mount bolt (AC compressor to bracket bolt) cross threaded into fan bracket (seen this once before), was a bear to get out.
Excessive crankcase pressure (combustion gasses):
I woke-up thinking, it may be leaking so badly, because of excessive crankcase pressure. Pressure as a result of excessive combustion gasses. I had noticed, when I pulled air pipe. The relatively new OEM PS side PCV hose a bit oily at each end, which I found curious. In addition, due to some vacuum leaks concerns, I'd found and corrected in a past service. I did a compression test a few days ago, before pulling T-belt. I did find 4 low, and 1 of those cylinder below minimum. Wet-test confirmed, all 4 compression loss at rings.
The 4.7L 2UZ would likely go 1 million possibly even 2 million miles, without compression going below minimum. If properly maintained and service. It is one of the greatest engine ever built IMHO.
But I've see compression issue many times, due to a few things other than blown head gasket(s) & warped head(s) due to cooling issues (improper service). Those dealing with either improper (lazy) service when R&R intake manifold (No. 1 cause of failing compression test), air filtration issues (weak compression), oil & filter issues (weak compression), COP (coil) top seals not replaced (No. 2 cause failed test). Failed compression or low compression, these 4.7L engine will still run most times good enough. There are many on the road with low compression. That I'm sure of. They just keep ticking!
To reduce crank case pressure. Proper vacuum (no leaks), and a good PCV valve are important consideration:
So, I'll toss on new PCV valve. Very likely it's gummed-up some, although not stuck last inspection. This could help reduce crank case pressure.
Crank seal may help, if it indeed is leaking the major leak point.
Some AT-205 can help with oil pump to block O-ring seal, and other rubber oil seal.
Cam seals look fine, so I'll not touch those. In fact I've never had to replace factory cam seal.
