Hiluxforever
- Thread starter
- #61
Yes. I have been super super stressed about this since August.You got lucky. Wow.
But after my bad accident on the second day of the new year I needed a break.
Radiator failure'Lucky' is not how I would characterize a $7,000 repair bill.
Blown head gaskets are not a common GX460 issue. Why do you think yours failed?
Did your car overheat? Did you ever change the coolant prior to reaching 100k?
Can you elaborate? Did you keep driving it after your temp gauge pegged?Radiator failure
Great news!Just got it back from the Dealer. With a new Starter it was just under 7k with tax.
Absolutely. I have had 13 other vehicles go through my hands that needed zero engine repairs, so I was overdue for a hit there.Great news!
Looking at the big picture, $7k is a lot cheaper than having to junk you vehicle and buy a new one.
And on that note, you should be good for another couple hundred thousand miles now! Or about 10 to 15 years?
So, yeah, that was a painful pill to swallow, but better than the alternatives.
Being lazy and not bothering to search, did you have a valley plate leak earlier?I have been doing a lot of thinking, and I dont think my second radiator failed. I think it was the head gasket the whole time.
It got me wondering, and I would be curious to see how many people with head gasket issues also had valley plate issues and if the headbgasket failure could induce valley plate failure through excessive pressure to the gasket compound.
Yep. Done a year ago with a timing cover reseal. My cooling system issues were an 18 month thing.Being lazy and not bothering to search, did you have a valley plate leak earlier?
Yes, my first radiator failed at 120k and thats when my cooling system issues started. At 145k it started rolling white smoke at startup and I bought a commuter, which was then totaled out on the 2nd of January in a severe crash. Thus triggering the repair of the GX before I had all the money saved.Did you ever change your coolant prior to the valley plate repair?
Everyone knows that already.I've asked about your coolant change because old, acidic coolant is directly related to the gasket problems (head and valley plate) that you experienced.
Lexus recommends changing the coolant at 100,000 miles (or 10 years). Afterwards, the interval is every 50,000 miles (or 5 years).
The Car Care Nut and others suggest doing the first change at 50,000 miles.
Why is this important?
(the following is copied from AI)
Effects of Acidic (Old) CoolantCoolant contains corrosion inhibitors that maintain a specific pH balance (typically alkaline). Over time, these inhibitors break down, and the coolant becomes acidic.1. Corrosion of Internal ComponentsOnce the coolant turns acidic, it begins to eat away at the metals it touches. In a GX460, this primarily affects:• The Aluminum Engine Block & Heads: Acidic fluid can pit the aluminum surface.• The Radiator: It can lead to "pinhole" leaks in the radiator core.• The Water Pump: Acidic fluid can degrade the pump's seals, leading to premature failure.2. The "Achilles' Heel": Head GasketsThe GX460's engine uses multi-layer steel head gaskets. If the coolant becomes acidic, it can begin to eat through the delicate coating on these gaskets. Community data suggests that neglected coolant is a primary contributor to head gasket failures on high-mileage 4.6L V8s.3. Valley Plate LeakThe "valley plate" is a plate located in the "V" of the engine that seals a coolant passage. Acidic coolant can degrade the sealant used here, leading to a slow, "crusty" pink leak that is notoriously expensive to fix (often $1,500+) due to the labor required to reach it.
