- Joined
- Feb 19, 2012
- Threads
- 119
- Messages
- 1,280
I been using this with no issue. Pretty cheap at Walmart. I run it up to 5k miles at a clip
Bump...
I came back from a 1000/+ mile plus trip and i noticed a blot of oil on the driveway. I looked underneath and a fourth of the front plate was covered in oil along with the diff and front oil pan and hoses. I use 8qt's at changes so i went down to the FULL hash mark.
I run M1 Extended Performance 5w-30. This is designed for 1/yr oil change interval. Using it for the past 2-3 years now.
When i did the TB i replaced all seals. I have had a slight leak from crank for a long time and never had any drops on driveway or enough to notice a change in level on the dip stick. I believe this leak is due to the oil thinning and causing a greater leak[?] I checked the manual and i can go to 10w-30. But from what i read that just thicker starting weight and that the viscosity [30] is same as 5w-30, so i dont think this will help.
Not sure i want to go to anything higher then 10w-30 per manual. Thoughts? Maybe a bad seal install? Possibly a scratch on the crank causing the leak?
Also, i stayed between 65-70 the whole time so i was not abusing the engine at all. Currently at 230k on engine.
Oil will not leak if seals are properly intact. You must have missed the cam seal or something obvious to lose 1/2 qt?
I really don't see a 10w oil helping out.
Yeah.... I think this is a seal issue. I still have 50k miles before next timing belt. Just going to deal with it until then. This was the first time it got this bad. Gonna clean with degreaser and keep an eye on it.
