Oil for 93 HDJ81V -1HD-T Auto
Fiji
Sorry If I'm repeating the questions that may already have been answered.
Just an excited noob who got his hands on a 80 :)
I have always liked the 80 and have recently bought myself 1993 HDJ81V - 1HD-T automatic with 207k's on the clock.
1. The old owner used Total Energies FLUIDMATIC DIII MV in the transmission - is it ok to continue using this oil as the dip stick says to use a Dex II (has A442F Trans)
2. What oil to use in the front diff and transfer case (recommended Brand?)
3. What oil to use in the rear diff (has a K295 axle i think this means LSD)
Appreciate all the help i can get
P.S: Im in Fiji Islands
Welcome to MUD
You can download a copy of the Factory Service Manual (FSM) in the RESOURCES section at the top of the page.
(here it is):
For diesel specific questions consider also checking the Diesel forum.
Check in the FSM (see link above) for the HDJ80 fluid recommendations.
Here's another link, scroll down to HDJ80:
Copied from the thread linked above:
Vehicle: Toyota Land Cruiser (HDJ-80)
Engine model: 1HD-T (12 valve) or 1HD-FT (24-valve), 4.2L inline-6 cylinder turbo diesel-engine
Fuel type: 48 cetane number, 95L (+50L with sub-tank)
Engine oil, 1HD-T: API CD, 9.3L (with oil filter change)
Engine oil, 1HD-FT: API CD, 9.7L (with oil filter change)
Coolant, 1HD-T: Ethylene-glycol based, 11.9L (with fr/rr heaters)
Coolant, 1HD-FT: Ethylene-glycol based, 12L (with fr/rr heaters)
Transmission, manual (H155F): API GL-4 or GL-5, SAE 75w90, 2.7L
Transmission, automatic: ATF Dexron-II, 15L (dry fill) or 6L (drain & refill)
Transfer case, HF2A and HF1A: API GL-4 or GL-5, SAE 75w90, 1.3L
Transfer case, HF2AV: API GL-4 or GL-5, SAE 75w90, 1.7L
Power take-off: API GL-4 or GL-5, SAE 75w90, 0.1L
Winch, mechanical (2000 kg-f): API GL-4, SAE 90, 0.5L
Winch, electrical (1000 kg-f): ATF type F, 2L
Differential, front: API GL-5 hypoid gear oil, SAE 80w90, 2.8L
Differential, rear: API GL-5 hypoid gear oil, SAE 80w90, 3.25L (use LSD oil for LSDs)
Power steering: ATF Dexron-II, 0.8L
Propeller shaft: Lithium-base multi-purpose, NLGI-2
Wheel bearing grease: Lithium-base multi-purpose, NLGI-2
Brake fluid: SAE J1703 or FMVSS 116 DOT-3
Added to above list: the driveshaft Slip Yolks require Lithium base Molybdenum fortified grease as do the Steering Knuckles/CV joints
