I know i'm going to be ragged a bit for this one, but I just purchased an oil extractor so as to be able to do oil changes at home. I don't have much of a garage or smooth place to work.
It uses a vacuum pump to suck the oil out of your oil pan (inserted through the dip stick tube) so you don't have to crawl under the truck and drain it from the oil drain plug. I used it this morning to change the oil in the Mercedes and it only took about 20 minutes to change the oil.
here is a link:
http://www.pelaproducts.com/description.htm
I got the 14 liter model since the mercedes holds 8 liters of oil.
here is a link:
