After fitting a mech oil gauge to check the pressure I've noticed,especially when the truck has been parked overnight, that the oil drains partially back down the tube into the sump and presumably from the rest of the oil galleries also.I thought there was some sort of valve in the pump to prevent this?
On cold startup there's 3-4 second timelag before pressure registers on the gauge.Is this normal? Using 10w40oil.Pressure hot & cold is fine once running.
