Oil drain plug washer?
Tauranga New Zealand via Vancouver Island Canada
What size is the copper washer on the 3B engine oil pan drain plug?
Also, size of oil and fuel filter o-rings?
NAPA tells me they can't look them up, and I don't have a second vehicle.
Moose
the oil filter and fuel filer comes with the new o rings.
get the drain plug gasket from Toyota, cheap.
don't know the copper washer, but it is ~0.5$ from toyota, and they will know. it is the same size for any land cruiser up to 93, I think.
the number for napa oil filter that will fit is Fram PH8A
Fuel Filter:
Napa Gold 3393 (the napa filter is slighter taller than toyota so you need to loosen the mount to get in installed)
enjoy!
NAPA Gold 1515 oil filter. I am using the NAPA Gold 3393 for a fuel filter, but I understood that this was because the 13BT returns a lot of fuel and you need a bigger filter for it. When I asked the guy at NAPA to look up "3B" in his listing, he initially gave me a NAPA Gold 3383 as a fuel filter, which was slightly smaller in size. Don't know if it makes any difference.
i would suggest that it would depend on how often you change out the filter... most guys do every second oil change...
