Last week i had the heater T blow up on me. I noticed dripping from the radiator. I have narrowed it down to the two bolts on either side on the bottom. I cant find any other location where i see coolant dripping. Will need to replace radiator.
When i did the timing belt i replaced both cam seals. There was oil on the PS and i thought i took care of it with the new seals. While looking for the coolant leak i noticed that once again i have oil leaking from the PS cam seal.
There are a few threads mentioning the PCV being a possible problem for this. Is there another problem area i missed while doing the timing belt? I dont see any leaks from the HG seal or any leaks above the cam seals for that matter.
Is there another seal behind the cam seal i missed? I have a non VVTi so i dont think i have a seal internally to the crank.
1. This part does have play in it.
2. Oil around the cover.
3. Not sure what this is, but its oily also.
Thanks!
Thanks!
