For Sale OFFROAD CAMPER
ONE OF A KIND OFFROAD CAMPER BUILT USING 15 YEARS OF EXPERIENCE IN THE RV INDUSTRY. LAST 9 YEARS AS A SERVICE/SHOP MANAGER.
I Have Used This Camper Many Times Staying On My Land In Colorado @9,500 Ft In Elevation @-18 Degrees Below Zero. Thanks To The Suburban 30,000BTU Forced Air Furnace I Usually Just Wore Shorts And A T- Shirt While Inside. This Is The Same Size Furnace That Is Used In Larger 5th Wheels.
I've Never Had It Weighed, But Estimate It @2,000-2,500lbs. I Used My Mercury Mountaineer w/ A V6 And Have Pulled It Over Many Mountain Passes In Colorado.
LIST OF SYSTEMS:
16 Gallon Fresh Water Holding Tank w/ Low Point Drain
12V On Demand Water Pump
Exterior City Water Connection
Suburban 6 Gallon Water Heater
Stainless Steel Kitchen Sink w/ Pullout Spray Faucet
Suburban 3 Burner Stove Top
Exterior Shower
Trip-Lite 1000 Watt Inverter w/ Remote Switch And Battery Status Indicators
Pre-Wired For Onan Generator w/ Interior Start Switch
Two 6 Volt Interstate Marine Deep Cycle Batteries Using 2 Gauge Wiring (NEW)
Battery Cuttoff Switch
Lippert 3500 lb. Axle w/ Electric Brakes
INTERIOR SOUND SYSTEM:
Sony DVD/CD Stereo w/ Front Aux Jack For Mp3
Two Bose 101 Speakers
Aiwa Powered Subwoofer
EXTERIOR SOUND SYSTEM:
Power Accoustic Stereo w/ Front Aux & Blutooth
SSL 1600 Watt 4 Channel MOSFET Stereo Amplifier w/ Remotely Mounted Subwoofer Volume Control
Four 6x9 3 Way Kicker Speakers
Two 10" Sony XPLOD Subwoofers
All Speakers Are Mounted In The Rear Lift Hatch. I Built The Hatch Using Airplane Wing Gusset Technology For Added Strength. The Speakers are Mounted In Between Each Gusset And Have Tremendous Sound Projection. The Sound Is Truly Amazing. There Is Nothing Else Out There Like It.
Exterior Walls Are Constructed Using Marine Grade Gelcoat Fiberglass That Is Vaccuum Bonded to
1/4" Cabinet Grade Plywood.
All Walls, Ceiling, And Floor Are Insulated Using RV Grade Insulating Styrofoam. This is The Same Stuff
Used In High End Motorhomes And 5th Wheels.
LED Lighting Throughout
Blue LED Undercarriage Mood Lighting
12V Electric Tongue Jack
12V Rear Stabilizer Jacks
30 Amp Converter/Charger
3 Exterior 110V Outlets
Exterior RG6 Satellite Coax Connection
Roof Raises For Added Headroom And Lowers For Travel
Ceiling Skylight w/ Sun Blackout Shade
All Windows Are Factory Tinted And Have Day/Night Shades
Multiple Drawers Throughout
Two Hanging Clothes Closets
THIS BUILD HAS TRULY BEEN A LABOR OF LOVE AND NO EXPENSE WAS SPARED.
I HAVE MADE MANY MEMORIES CAMPING IN THIS AND NOW ITS TIME FOR SOMEONE ELSE TO START MAKING THEIR OWN.
THIS WILL GO VIRTUALLY WHEREVER YOUR 4x4 WILL GO.
TRULY A HEAD TURNER.
I CAN'T TELL YOU HOW MANY TIMES I HAVE BEEN FOLLOWED JUST FOR AN OPPORTUNITY TO TAKE PICTURES.
I AM DOING A FRAME OFF ON A 1965 FJ40, (keeping it all original) AND WILL USE THE MONEY TO
COMPLETE THE BUILD.
$27,500
Pm ME FOR MANY,MANY MORE PHOTOS OF THE BUILD.
Wow - you built this yourself?! That's outstanding - nice work and I hope it goes to a good home!
Bump for an amazing trailer - would love to see the build thread if that's available. GLWS....
