Well I spent a good hour and a half last night reading through that thread and others and took away some key lessons:
1. Don’t back up while in a Forward Gear: throw it in neutral or better yet reverse to take advantage of the engine braking. I think my 80 was more forgiving in this scenario as I let it slide down while in forward Gear for a good 10 seconds before I started seeing problems
2. use 2 feet while negotiating a hill, one in the brake and the other on the gas. Keep the brakes on and add throttle as necessary to stay put/go forward
3. Make sure your brakes work and e brakes work. I happened to mess around with the BB pushrod a couple months ago and may have compromised the gasket between the booster and MC leading to a sight vacuum leak in the booster. Didn’t notice or think it was an issue until yesterday. My e brakes weren’t even adjusted so I knew they were no use as I accelerated down.
4. Make sure your brakes and associated components (LSPV and abs module) are purged of all air: didn’t think my brakes were an issue and thought the slightly low/spongy feel was due to me driving sedans all my life but apparently the brakes on the 80s can “throw you through the windshield” if bled correctly. Also noticed the braking performance while backing down a hill is pretty poor, will look into possible mods to improve this...
5. Lock your diffs: I don’t have a CDL switch and the light itself is burnt out so there isn’t a way for me to tell If I was locked or not.
Luke
Very important. If you don't lock your Center Diff....it will act as an 'open' diff. So when/if you lose traction in the front (in a significant way) the vehicle will want to roll backwards...which can initiate the whole 'roll back' issue to begin with. The 'natural' reaction for most will be to give the vehicle more throttle....but because you are in drive and rolling backwards....this can result in a stalled engine.
