For Sale OFF-ROAD CAMPER
This is a one of a kind custom built camper designed to be taken virtually anywhere.
If your Tow Vehicle can go there, this Camper will follow.
If you're a hunter, this is the Perfect Rig for you.
Weigh's only 3000 lbs.
LIST OF SYSTEMS:
16 Gallon Fresh Water Holding Tank w/ Low Point Drain
12V On Demand Water Pump
Exterior City Water Connection
Suburban 6 Gallon Water Heater
Stainless Steel Kitchen Sink w/ Pullout Spray Faucet
Suburban 3 Burner Stove Top
Oster Microwave
LIT 32 Quart IGBC Certified Bear Resistant Cooler
Exterior Shower
Trip-Lite 1000 Watt Inverter w/ Remote Switch And Battery Status Indicators
Pre-Wired For Onan Generator w/ Interior Start Switch
Two Marine Deep Cycle Batteries Using 2 Gauge Wiring (NEW)
Battery Cuttoff Switch
Lippert 3500 lb. Axle w/ Electric Brakes
New Mud Trac LT315/75R16 Tires
INTERIOR SOUND SYSTEM:
Sony DVD/CD Stereo w/ Front Aux Jack For Mp3
Two Bose 101 Speakers
Aiwa Powered Subwoofer
EXTERIOR SOUND SYSTEM:
Power Accoustic Stereo w/ Front Aux & Blutooth
SSL 1600 Watt 4 Channel MOSFET Stereo Amplifier w/ Remotely Mounted Subwoofer Volume Control
Four 6x9 3 Way Kicker Speakers
Two 10" Sony XPLOD Subwoofers
All Speakers Are Mounted In The Rear Lift Hatch. I Built The Hatch Using Airplane Wing Gusset Technology For Added Strength. The Speakers are Mounted In Between Each Gusset And Have Tremendous Sound Projection. The Sound Is Truly Amazing. There Is Nothing Else Out There Like It.
Exterior Walls Are Constructed Using Marine Grade Gelcoat Fiberglass That Is Vaccuum Bonded to 1/4" Cabinet Grade Plywood.
All Walls, Ceiling, And Floor Are Insulated Using RV Grade Insulating Styrofoam. This is The Same Stuff Used In High End Motorhomes And 5th Wheels.
LED Lighting Throughout
Blue LED Undercarriage Mood Lighting
12V Electric Tongue Jack
12V Electric Rear Stabilizer Jacks
30 Amp Converter/Charger
3 Exterior 110V Outlets
Exterior RG6 Satellite Coax Connection
Ceiling Skylight w/ Blackout Shade
All Windows Are Factory Tinted And Have Day/Night Shades
Multiple Drawers Throughout
Two Hanging Clothes Closets
Blue LED Interior Mood Lighting
All Cabinet's Are Built Using Real, Solid, Wood. No Cheap Wrapped Imitation Stuff!
This build has truly been a labor of love and no expense was spared. I have made many memories camping in this and now it's time for someone else to start making their own.
This will go virtually anywhere your 4x4 will go.
Truly a head turner.
I can't tell you how many people have followed me for miles just for an opportunity to take pictures.
I have many more pictures of the build.
$21,000.00
Nothing about the bed ?
Congrats on the sale! In the process of designing and building myself. You you have a build thread?
