OBDII Reader...
I did a search on this topic but I am wondering what the latest thoughts are. I've got a 96'LC with 140K miles that just started a trouble light signal today. Called the dealership and they want $50 to read the code. Figured that's a good start to paying for a scanner but have no idea what might be the best for minimal $'s. Would like to stay with $100 to $250. Any suggestions?
Or, anyone in Salt Lake City that would be willing to read it??
Thanks.
harbor freight, $40 for reader/eraser
Most Auto parts stores will read them for FREE. Some don't, call first.
if you're a gadget geek, check this out: http://www.autoenginuity.com/. Just received my sw and interface for an ipaq today (about $230). Cleared a code 420 with it ( i have an exhaust leak that I think is causing it, and borla is sending me a new exhaust to correct this).
I'm up near ogden if you want to run up the road and check it out. pm me.
randall
check the Vendor corner, I picked up the one listed in there and installed the software on my laptop...allows you to have a full dashboard setup on the laptop, so you can see things as they operate...also possible to see how close to the min/max values a sensor may be operating at, and perhaps change something before it's fully junked.
$160ish...I think....just need a serial port on your laptop (or usb --> serial adapter)
I've got the Harbor Freight reader/eraser also, paid $40 for it. Works fine for what I need it to do. It's so easy to use I can clear my pesky 300 code while driving down the road.
Tony
Thanks all. I'll probably grab one of the cheaper ones later today. And Randall, depending on how this works out I might take you up on your offer. I appreciate the help.
Paul
yes, one can have the codes read by some Autozones etc, but for $40 I'd rather have one with me on the road that I can use to diagnose a possible problem on the go...
I just cleared a 420 code with a HF cheapie code reader. There are a bazillion code readers out there, but until you get one that can do real-time monitoring of your engine, it looks like most of them just allow you to read and clear a code. In the middle somewhere, are the laptop-plug-in models. There are $150 readers that do no more than the $40 one - they just have dedicated buttons for certain features.
I think the OBD reader industry has done a lousy job of clearly classifying readers into categories to help you figure out which one to buy. So, I used a cheapie and searched this list to find the possible sources of my problem. Good luck!
Steve
Would this work for a '94? Or do I have to use the jumper and count the bllinks?
