O2 sensors
what happens if you dont replace a bad O2 sensor? i need to do mine, but haven't and now I get kind of a throaty sound and loss of power. I assume it's because the computer can't adjjust because it's not getting data from the sensor. I also hope I'm right and this problem goes away when I put new ones in.
Also, what's the difference (listed on SOR) between regular O2 sensors and "U" sensors?
Biggest thing is the decrease in MPG'S
Great. I think I'll go that route. Cheaper than the OEM on SOR, and not much more than the used ones--I'd rather have new.
The Denso lists a passenger side and left side, is there a difference? The Bosch doesn't have a similar distinction--can I just get two of those?
That's not a real good place to look for OEM pricewise, unless it's some cool non-USA part.
Call Cruiserdan, Champion or someone that sells OEM at alot cheaper price than Specter.
Don't get me wrong Specter is an asset , just not for buying most new genuine parts.
did they have the oem connector?
I got one recently and yes, it does.
The best thing is, you can unscrew the sensor from the flange that the stock sensor mounts with and use a regular weld in bung (or nut) if you are making a custom exhaust.
-Matt
