Quick question for those that have gone this route - did you remove the output seal on the NV4500 to make this work? The seal supplied on the NV4500 is 1.910" ID and the Atlas input is 2.175" OD, so they do not fit. When I called AA about it, they said the problem is the NV4500 is designed to be used with a thinner walled tcase. Their solution is to remove the output seal on the NV4500, mate the 2 to determine the clocking of the Atlas, and then use silicone for sealing. Sounds kinda "duct tape and bailing wire" to me, but if that's the solution, so be it.
Anyone been down this road and care to comment?
