Nv4500 costs and sources
I think the chevy aluminum version was the one in question, I'm sure a 6BT BH would be just fine. This is all hypothetical for me so far, I haven't started spending the big $$$$ yet.
D'animal- I have heard that a "good" rebuild kit for a nv4500 costs $600 to $1000- I suppose this would be domestic or OEM parts vs. overseas parts? Did you have to send or core? If not what did they charge for the core?
The output shafts are the thing that you have to look at. If you get the wrong one, it will have the wrong output shaft and mating it to an Orion gets expensive. (You ahve to replace the output shaft and then cut it off)
It was $300 for the core.
When they rebuild them, they have the 5th gear fix they do automatically.
I call AA yesterday a payed for my nv4500 bellhousing and my adapter to go from the nv to my LC split case. I didnt have the funs to pick up the ORION HD. I wish i did. when those get here i am going to see ALL TRANS in portlamd to get my first gen GM NV4500. I can't wait tell i can turn the key again.
Joe
According to AA, the internal slave cylinders are very difficult to make work. The Chevy bellhousings with external release mechanisims had the throwout arm low on the passenger side, right where your front driveshaft can smack it, even with SOA. Furthermore, it is made from stamped junk, not nearly as sturdy as the older, cast steel pieces from the 70s and 80s, so it is to be avoided. The Chevys all have the 32 spline output as well as the dampener, Dodges have either 29 or 23 splines, depending on the motor it was mated to, and no dampener. The Dodges all used internal slaves. Chevy used external through 1995, then went internal. The input shafts on the Dodges vary as well and so do the front retainers requiring specific hardware or a change to a different retainer. The low-ratio Chevys were used up through 1994 inclusive. Chevys also had a shorter shifter throw than the Dodges, much better feel. Dodges later changed to a similar setup, I can't remeber what year that was. All NV4500s have the shift tower on the rear of the trans (Toyotas are on the front) making it ideal for a V8 conversion. Having a higher ratio unit, the 5.6:1 first gear, I can say that I am glad I did NOT get the lower ratio. As it is I hardly use first gear at all. What I ended up doing was using a '95 Chevy bellhousing from which I removed the original junky release hardware and welded the opening over with some plate aluminum. I cut a hole in the driver's side, made a steel plate to which I welded an old-school release arm pivot and securely bolted that to the bellhousing with recessed fasteners that would not interfere with the contact area between the trans and bellhousing. (this took patience and dremel time) Then I made a bracket that attaches to two of my bellhousing bolts to hold the slave cylinder. This has been working for two years now with no problems at all. It ranks high on the redneck scale, but I'm not rich enough to buy the AA bellhousing. My overall opinion of the NV4500 is that it is the best transmission I have ever had. It is super quiet, shifts very well and I love the ratios combined with my 350. It replaced an H55F which I also liked, but this is better.
Thanks for the info. I think I have the low ratio version.. I looked at an early blazer with a 4bt and the ZF- Bino on 'swaps- and he was running 3.?? R&P and said it performed like the V8 with twice the fuel economy: 23mpg.. Fun stuff..
If you're in doubt, you can tell by removing the top cover and counting teeth on the input gear. The early Chevys with the low ratio had 20 teeth, the others had 22.
What size tire?
I have a NV 4500 from a 2001 Dodge 1 ton 4x4 and run 4:88s on 39" Irocs and getting 21 - 22 mpg on the flat lands of California. I use first gear and the engine is purring in 5th.
My MPG are not mathmatical calculations. I fill the tank up till it is overflowing, drive 100 miles and fill it up till it is overflowing. 5.3 gallons of diesel. :D
I have 4:11's in my tow rig. It is built for pulling and does a great job.
The blazer had bald 31's and he planned on running 33's. I would prefer 33's myself but may go up to 315's (35"?) I don't think I can change the ratio in an fzj80 which has 4.10s and I don't think anything higher is available (like a 3.73 (?)) in a 60 series.
Most if not all FJ60s came from the factory with 3.70s. As far as the front of your 80 series goes, I don't know.
Wow, old Post! My swap is still working but oil is finding it's way into the t-case. I refilled with some amzoil and it shifts hard when it's cold... I guess it's time for a $130 change!!
