does anyone have any experience with np241's? I'm curious if I can clock it one hole upwards so the bottom of the tcase isn't six inches below my frame rail.The motor is mounted at the proper height and rearward enough to clear the heater. Im just having issues with clearance either below the frame or the underbelly of the body. Its chain driven so it should have a problem with lubricant if i clocked it up correct? if not, my options are 2'' body lift or cutting the interior flooring up 2-4 inches to give adequate clearance if I cant clock the tcase. Any suggestions?
