Nose too low! (1 Viewer)
Port Elizabeth, South Africa
I'm currently running OME 863's at the back and 851's in front. I've got an aluminium ECB replacement bumper and a KEW8000 winch with total weight of about 140lbs. Currently the nose is a lot lower than the back, at least 1.5" - 2" lower.
I'm obviously running the wrong set-up. I don't want to loose too much articulation and I don't want to go down with the rear. What can I do to fix this?
After searching the forum, I read that some are running 863's at the back and 850J's in front with normal OME shocks and nothing other than OME castor kit and swaybar drop brackets. Is this an option? Spoke to my fitment centre and they said they will sell me the 850J's but don't want to fit it as they feel the J's are not safe and I will have castor angle problems.
Barto
Will you have the swaybar drop plats manufactured yourself? I don't know if you noticed but I am having problems with my front swaybar touching the right control arm under corrugated road conditions.
