Noise I've never heard before (2 Viewers)
Fayetteville, AR
Bought a 97 LC a little over a month ago. Since then I've added an OME lift. For the past couple of weeks there has been a noise. It only does it at low speeds and for a few seconds. It's definitely tire/driveline related. It typically does it under 25 mph. The best way I can describe it is it sounds and somewhat feels like you're driving over one of those rumble strips (without as much vibration) before a stop sign. Doesn't have the feel of that as much as the sound. I can feel it somewhat though. The sound is what is annoying. I use my phone as a temp gauge and at first i thought it was my phone on silence vibrating. Any thoughts????
Travis
Turn up the radio. Always works for me. Stop when something falls off. If I think I need it.
...it sounds and somewhat feels like you're driving over one of those rumble strips...
I had that exact same symptom when my spindle bushing failed, which also happened to be right after I did my OME lift.
Spindle bushings.
