I've read through the forum, but I want to be sure there's not something I'm missing here. I would greatly appreciate any input I can get. My (dash cluster) oil pressure gauge is reading nothing at all... at any temperature. Everything seems fine except the gauge in the instrument panel doesn't budge (maybe it's just the gauge itself). My first plan, given the fact that I have 130K miles on the OD, was to simply replace the related sending unit (though I can't seem to locate this item - is that different from the oil pressure switch?). Then I started thinking that the oil strainer might be clogged, or the oil pump failing. None of that makes much sense to me since the gauge is not just low but stuck at ZERO (and at any temperature). Thanks in advance for any help.
