Mike6158
Random Pixel Generator
I've been installing a new Pioneer AVIC-5200NEX... I bought the plug and play wiring harness from Crutchfield. It's not plug and play by the way. Full disclosure- I despise installing stereos. I can work on the electronics and I enjoy that... but I'm often tempted to use a 2# hammer to install stereos (I don't but man that would be fun)... not a fan... in the least...
I finally got the harness temporarily routed and plugged into the amp jack and the radio installed. I attempted to power it up. Nothing.
great.
Initially I thought I was going to have to deal with Crutchfield Tech support and I was not really looking forward to it. They've gone down hill imho. I decided that I should check the power coming to the connector. 17 and 7 don't have power. The ECU has power (28) and the "cigar" jack has power (22). The fuses are good otherwise the ECU and "Cigar" wouldn't have power. Besides that I checked them and they are good. The auto antenna doesn't do anything either (in manual).
The only "radio" fuses I could find are in the fuse holder on the drivers side kick panel and the one in the big fuse box under the hood
More pics related to the post
The following are of the Toyota and Crutchfield harness connectors
Factory on the left. Crutchfield on the right
Crutchfield connector rear
Factory Connector Obviously the wiring is reversed from what it looks like plugged in. The connectors aren't the problem. The problem is the lack of power on Blue/Yellow and Gray wire.
