ignition
Post up a pic of the ignition you are using (the distrib and coil)---is it OEM, electronic? Points? Pertronix?
Does the coil have a box attached to it with a couple of green connectors on it?
At its most basic the power to the dizzy goes through the primary windings of the coil---it is triggered off either mechanically by the points or electronically by a sensor. When primary voltage goes off a big spike is induced in the secondary and gives you a spark.
Just to clarify--Do you have power to the coil and none to the dizzy?
it's only
