No more DRL after changing high beam bulbs to LED (1 Viewer)
OEMGUY0720
Der liebe Gott steckt im detail
USA
I recently took out my high beam halogen Sylvana headlight bulbs for an LED bulb:
I noticed the DRL disappeared. How can I put back the DRL? Wiring? Change to a different LED bulb?
Would appreciate for someone who encountered this and what was your solution for this. Thanks in advance.
2006 Lx470
DRL on the 100 is just a voltage drop on the highs. You cannot run most leds. Some will accept a finished voltage drop but it will be unreliable.
side note, the bulbs you bought are likely going to blind people. Run good quality halogens -or- don’t be cheap and get a good led replacement that actually designed to function in halogen housing. I’ve had goodperformance with the hikari ultras.
High beam on the 100 is just a voltage drop on the highs. You cannot run most leds. Some will accept a finished voltage drop but it will be unreliable.
At least they’re in a high beam and hopefully only used when people aren’t around.
truth. I’m also assuming the op put them in the low beam as well.
Not many things more irritating/dangerous the poorly aimed headlights and cheap led replacements in halogen housing.
Why I have an hid projector retrofit.
nice! On my list of things to do.
Why not do the same for the highs?
Can, just more work, but my Tacoma is a single high/low.
