Hi everyone. Since almost two year with this problem, I gived up and want try ask for a help here.
I have JDM LC80 93y with 1fz-fe AT. In the past I had high cold start idle like everyone, even done o-ring mod but suddenly one fine day it went.
Problem is happens every cold engine start, it won't keep high startup idle for fasting warm-up, no matter if is 5F or 86F outside, switch A/C On can increase idle, shifting P-R-N-D also increase idle too.
I have OBD1 Bluetooth device that connecting to smartphone, I can see full open IAC 125step. Usually after starting it's 70-60step for 1000-900-850RPM and slowly going down, it's can stay at 850-800RPM longer with 66-50-45step and only near to 40 step quickly decrease to a nominal idle of 650 RPM with 20-18 step.
I know, looks like pretty vacuum leak, leaning on low VAF 2-15-2-35 voltage at idle and low IAC step but I hooked hand-made smoke pump, and couldn't fine anything horrible, maybe I need check another more time.
Here is one cold start at winter from the past, I could feel unburned gasoline smell for a while maybe 1 minute.
THW 14F |. VAF 1.29V. |. RPM 875. |. IAC 86 step
after 8 minutes of warming
THW 113F. |. VAF 1.72V. |. RPM 800. |. IAC 58 step
Looks strange, because VAF show less air and IAC step close more, but idle speed the same?
And some more log
THW 78.8F | VAF 1.60V | RPM 850 | IAC 60 step
THW 89.6F. |. VAF 1.58V |. RPM 925. |. IAC 64 step
THW 80.6F |. VAF 1.52V. |. RPM 1000 |. IAC 67 step
THW 104F. |. VAF 1.76V. |. RPM 825. |. IAC 53 step
THW 64.4F. |. VAF 156V. |. RPM 850. |. IAC 65 step
THW 140F. |. VAF 1.92V | RPM 750. |. IAC 53 step
THW 62.7F |. VAF 1.45V. |. RPM 1025. |. IAC 78 step
THW 55.4F. |. VAF 1.43V. |. RPM 1000. |. IAC 80 step
THW 51.8F |. VAF 1.45V. |. RPM 850. |. IAC 79 step
THW 39.2F. |. VAF 1.45V. |. RPM 825 |. IAC 79 step
Now what have I done with car
TPS adjusted with IDL signal, disconnecting IAC connector got 2k RPM at cold start with 60-65 IAC step.
* 1 removing and cleaning throttle body, IAC, intake plenum, injectors (with new gasket kit), sealant intake manifold & throttle body
* 2 changed little vacuum hoses, PCV valve with gasket and hose, intake hose, bypass EGR
* 3 changed air filter, gasoline filter underhood, sparks, OX sensors, charcoal canister
* 4 checking ignition wires, distributor cap and rotor, looks in good shape, changed few years ago
* 5 trying and changing for a good used one, ECU, throttle body, 3 different IAC valve, 4 different TPS sensor, 3 engine coolant sensor, 1 VAF meter
* 6 servicing starter, alternator, neutral safety switch
Thanks and sorry for poor English, cheers
And some more log
