No heat.
Wilmington NC
Just bought out first 80 and the heat blows cold. Coolant level good. Flushed the front core. Tested the heater control valve( good). Noticed that when I removed the driver's side pipe supplying the core hot water while the engine was running there was no flow. Not even a trickle. Then I removed the radiator cap( not too hot) and pressurized the radiator with a garden hose and water blasted out of that pipe.
Bad water pump?
Truck runs cool with no overheating issues. Thanks for any advice?
Try posting this in the 80s section. This is for help with the site itself.
