FREE NH - "F" Engine Parts
New Hampshire
Getting rid of the "F" engine out of my FJ40. Cylinder #6 had a coolant leak while in storage, so I am dropping in a V8 now. Here is a list of parts that I have:
Cylinder head, I have 2 and they would need to be gone through. One will most likely need harden valve seats, the other has already has them.
Rocker arm shaft assembly, includes the oil line from the lifter valley
Bell housing for 3-speed with pan
Water pump pulley
alternator mounting bracket
Radiator - needs core replaced
Lifter valley cover
Flywheel - needs to be re-surfaced
Starter motor
Used 3-finger clutch, about 10,000 miles on it
Crankshaft
Engine block - is bored .030 over currently. Not sure if cylinder #6 will clean up with a .040 over bore.
I will add pictures as I dig the parts out. I can ship at your expense as well.
Intake Manifolds
  • Like
Reactions: flx
Hi there, unfortunately the thermostat housing is spoken for. The starter is still available. Approximate shipping to Phoenix, AZ is $50 via UPS. It will fit in a USPS Large flat box, but not much room for packing material.
radiator fan, 4-blade solid style
Water pump pulley
alternator, pulley, and mounting bracket
Lifter valley cover
Starter motor
Thermostat housing
Crankshaft
Intake manifold - I have 2.
Coolant heat riser for under intake manifold when using headers
The following items are still available:
Bell housing for 3-speed with inspection pan
Water pump pulley
Lifter valley cover
Starter motor
Crankshaft
