FREE NH - "F" Engine Parts
Getting rid of the "F" engine out of my FJ40. Cylinder #6 had a coolant leak while in storage, so I am dropping in a V8 now. Here is a list of parts that I have:
Cylinder head, I have 2 and they would need to be gone through. One will most likely need harden valve seats, the other has already has them.
Rocker arm shaft assembly, includes the oil line from the lifter valley
Bell housing for 3-speed with pan
radiator fan, 4-blade solid style
Water pump pulley
alternator, pulley, and mounting bracket
Radiator - needs core replaced
Lifter valley cover
Flywheel - needs to be re-surfaced
Starter motor
Used 3-finger clutch, about 10,000 miles on it
Thermostat housing
Crankshaft
Engine block - is bored .030 over currently. Not sure if cylinder #6 will clean up with a .040 over bore.
Intake manifold - I have 2.
Coolant heat riser for under intake manifold when using headers
I will add pictures as I dig the parts out. I can ship at your expense as well.
Is the fan blade still available ?
Any chance that starter is still available??
Yes, the starter is still available. Not how much it will cost to ship though. Shipping is a little crazy at the moment. If it fits in a flat rate box that will help. Will pickup a large flat box to see if it fits.
Great I sent you a message.
Thanks!!
Water pump pulley
alternator mounting bracket
Lifter valley cover
Starter motor
Crankshaft
Is the rocker assembly spoken for? I just need the rocker arm shafts. I'm on Martha's Vineyard or can possibly meet up!
The rocker a assembly is still available. This has the split rocker arm shafts with the oil supply fitting in the middle.
I already got a part from you on this engine Thanks What is the motor a F or a 2F? If its around 1972 i could use the inner(2 inside not either end) main bearing caps if you have them Thanks
Hi James, hope those parts are working out for you!
The engine is an F engine, but my FJ40 is a 1975, but I am sure the engines are the same. I think the drivetrain and engine were swapped out at some point, but who knows. I can PM you pictures of the caps if you would like.
