Well after lurking around in the corners for several months, I finally have a question to which I cant seem to find an answer to through the search engine.
I have a 1986 HJ60 with a HJ55 transmission. Today while I was parked and waiting for my wife, I put the car in first gear to pull ahead for the person behind me and as soon as I let go of the gear shifter, it just flopped over. The car was in gear still and so I put it in 4WD neutral so I could take a look at it. When I opened the 4 dust cover bolts I literally pulled the entire lever out, without having to release the retaining clip. When I looked at the retaining clip, it had broken on both sides so that it was no longer able to put pressure on the spring which holds the gear lever to the coupling below.
I have already found a new lever from an old transmission, but I'm worried about where the broken bits of metal from the retaing clip went. I am not very mechanical at all, and from looking at the Manual I have, I can't see if they were able to fall into the gears or if the gears are sealed below the point where the gear shift lever and coupling are (the little plastic ball)?
I know this isn't a very good explanation, but it was getting late and I don't have a digital camera.
Any ideas?
JZMQ
Any ideas?
JZMQ
